I'm out in the desert and got back from a ride yesterday and when I let off the throttle and the "engine braking" is on it makes a high pitched whining noise. Sounds like its coming from the clutch trans area. I'm not gonna tear into out here but thought I would ask what it might be. Is this a common thing? Belt? I've done the sheave and greaseless weights. Everything on the outside looks fine nothing obvious. Thanks for any suggestions.
Just want to be clear that this ISN'T the grinding type noise that is complained about when going down hill. It's a new noise that I have never heard out of any Rhino before. It does it only when I let off the gas and it's slowing down. It's not right I'm just looking for a starting point if anyone has had a similar issue.
One of my customers rhino had same problem we put a new belt on and used 500 grit to clean the sheaves and the noise went away . . . So u may want to look into that look at the belt real good to see if it's burnt . . .hope this helps.........
Brad
Paraprosracing.com.
Brad
Paraprosracing.com.
That's where I was gonna start but thought I would post up to see if there was anyone with a similar problem and fix for it. Thanks for the suggestion.
Justin
