just got some hid lights from utv inc. for 2006 rhino. looks to be good lights so far for 80.00 bucks . they were plug and play took a while to figure it out. everything had tags where it ties in. very bright . no high and low beam but you want need them. ten times brighter than stock
Got the same kit for my 06. Love them!
However, I learned a couple things about that particular kit:
If you play in water and mud, make sure you keep the relay and inline fuse holder dry. My relay burnt out because it isn't sealed. Had to replace with a sealed one. The fuse holder isn't water resistant either and will lose continuity when the fuse blades get gunked up. I replace it with a water proof holder and put it along with the relay, inside the battery box.
