I have a rhino 660 but I am selling it to upgrade to a 700. I primarily use it for hunting. However I will put a 6 inch lift with a rear seat and I still want it to have major balls. I am considering a big bore kit but the most important thing to me is reliability. What should I do? Don't need the fastest rhino but don't want to suffer. At least spin the tires and have some balls!! What combo do I need??? Please help!!
I have an 09 700 that is a four seater with cage, rear bed extender, and 25X10X12 front and rear. The only engine mod I have done is the JBS HOT ROD sheave set up. I use mine for hunting and running around the mountains and high desert and am very happy with the sheave. The low end makes it nice for when when your just putting arond the hills and the top end makes it fun in the open. Easy mod and reliable. Just be heads up on the secondary sheave with the 700. When I pulled my cover off to put the sheave on I found one of the rivets came out and I had to replace the secondaries, fixed primary, and belt. I got all from James for a good price and he said Yamaha changed the part number and he did the same on his machine and has had no issues after. My opinion, hold off on the lift.
