1 - 11 of 11 Posts
Need help dont know what going on witn my rhino 660
It starts and run about 4 to 5 feet then die pls help
2008 700EF
We'll need a lot more information to help you. Does it immediately re-start after it dies? Does it bog down and die? Does it feel like you just turned the key off when it dies? Does it rev up, then die? Any more information you can provide will help immensely. Did it just start doing this? did you change anything before it started doing this like add some lights or change wiring? Can you sit in neutral and rev it up?
Does it immediately re-start after it dies? Yes
Does it bog down and die? Yes running for 10 or 20 sec than die
Does it feel like you just turned the key off when it dies? Sometimes
Does it rev up, then die? Yes and I wish I can upload a small video 😆 but I can't don't know how
When I start it up and let it set for 5 or 10 minutes in neutral yes I can rev it up but sometimes it die and most of the time yes it will die on gear ...the last time I drove it for awhile good 5 mins or more than die and i just repeat over and over to make home
Sounds like it's not getting fuel and/or air. Time for a tune up if it's not been done recently, including servicing the air filter, new spark plug and clean the carb.
Have you communicated with the people who did the work about the poor performance?
Try taking off the fuel cap and give it a try. This test is to determine if its got an air flow issue.
I also don't see anything about the air filter on the receipt. Have you cleaned and oiled it recently as well?
I had the same problem with my 660 I put on a new billet aluminum fuel pick up on the gas tank and a new fuel pump I haven’t had any problems sense.
1 - 11 of 11 Posts
