Folks,
so I broke the STOCK right rear/passenger axle. its snapped up inside the CV boot. So I was able to get the old axle off easy enough.
Problem: Inner CV is still there and I dont know how to pull it off? Is there a secret to this?Shouldn't it pop out?
UPDATE:!
OK cut off the CV Boot and the axle is snapped off right at the bearing UGH!!! Any suggestions?
you can take cv out on the other side and pound the broken one out. its extra work but work in a pinch
I have used a vise grip and a slide hammer with a hook to remove the cup.
Discussion Starter #6
Thank you ALL!! I was able to pop it out by tapping on the rim of the CV joint cup where it seats in the Diff.
New axle installed :)
Thanks again Rhino Forum!!
