I bought a 4 light Hella kit from Vic's and I cannot get the lights to come one. The power switch illuminates and I can measure 12.45v at each blue power clamp on that combines the main power wire (ACC) from the switch with the red wire from the Hella light.
What am I doing wrong? Also, where do the Hella lights get their ground?
Can I assume that there's a relay involved? Does the relay show 12 volts on it's output (pin 30)? Are these HID's or standard halogen?
I figured it out. The light bar is supposed to be the ground as the housing for the Hella light frame is also the ground. I went ahead and ran a ground wire from the top roll cage bolt to the housing bolt of the first light and all four came on.
I believe the powder coating of the light bar is preventing a good ground and I didn't feel like taking it all apart just to sand stuff down for a good contact.
