1 - 10 of 10 Posts
Has anyone tried swapping out the OEM head lights with more efficient LEDs? I'm not interested in doing any excessive wiring or adapting to OEM - just looking for an upgrade that is "Plug & Play" and brighter than original equipment.
Thanks!
2009 Yamaha Rhino 700 Sport Edition
Thanks!
Just did mine. Found some sweet ones on Amazon. They are stupid bright. And they just fit where the stock ones were. No re wiring or anything.
Dang - I don't have any Canadian dollars! :(
Seriously though thanks for your input - that's exactly what I'm looking for - plug & play! Heading to amazon right now.
No worries. They’re a good upgrade. We do a lot of night runs 😉
2009 Rhino 700, Hunters Edition
I recently performed the same mod with very similar results experienced by PChow, with one notable exception. The high and low beam switch positions are now reversed. This appears to be a common problem with these replacement bulbs as I have read it happening to other forum members. It doesn’t bother me as I simply switch the light to whatever the conditions warrant, regardless of the little symbol that I can’t see in the dark anyhow.
Yes. Me too. It seems the manufacturers bulbs are backwards but it doesn’t matter. One position is still high beam and the other is still low. I never use the low beams anyways as when we wheel in the dark I want as much light as possible.
1 - 10 of 10 Posts
