I've had a problem with starting. It makes almost a full revolution and then the starter stalls. I would do it every once in a while before I re-ringed the motor. Now it does it every time. The battery seems to be strong but I will try to jump it with a good battery to rule it out. I'm thinking something electrical but am open to any ideas.
I hooked up the jumper cables and it didn't make any difference. I'm wondering if I have a grounding issue. I have lost the ground to the cage for some reason, my dome light quit working. But I have battery voltage to the bulb just no ground. I also have no ground at the cage bolts that separates the upper and lower halves.
