1 - 2 of 2 Posts
I have a 2008 rhino 700 and it starts hard. when i try to start it, it seems like it is kicking back. The timing is good and the valve lash is good. I did change the piston and rings awhile ago. just wondering if I got a high compression piston by mistake would that cause it to start hard. How is an easy way to check if there is a high compression piston in there? any other ideas ok what the problem could be would help.
1 - 2 of 2 Posts
