Chock wheels
Remove rear skid plate
 Move the parking brake lever to the
released position.
Remove the spring on parking brake caliper
Loosen the parking brake arm nut
Turn the push rod in fully, and then turn it
out 3/4 turn.
Tighten the parking brake arm nut
Install the spring and skid plate
If you do like Roo says; and, what James shows you in the vid...you will get all the life outta the pads. I didn't know about this, and replaced mine when they were only half worn!! After doing the mod James shows..I have put over 1000 miles on the new set w/only one adjustment !!
