1 - 12 of 12 Posts
Looking to buy set of half doors what's people running. What do you think is the best?
There are alot of nice doors out there,,,,imo...custom doors are the best when you make them yourself.i made mine fron 3/4"square tubing and a sheet of 1/16" aluminum,mine are half doors or full depending on the weather..i used factory location for mounting...good luck in your quest..
I would guess it is according what you do with your Rhino. I use mine to hunt....I like the J-Strong half doors and they work great for me.
J strong doors fit well, but they are way over priced for what you get. Haven't had any problems yet, but with as light as they are I can't see them lasting long.
i will try to upload a couple tomorrow at work....on my break...LOL.
I got my J strong 1/2 door on sale for $178.....just over $200 with shipping. I have had them on for nealy 2 years without any problems. I did modify the latching system, and they work like a champ.
I got my J strong 1/2 door on sale for $178.....just over $200 with shipping. I have had them on for nealy 2 years without any problems. I did modify the latching system, and they work like a champ.[/QUOTE
any pics on how u modified your latches ?
X2...the latches SUCK !!!
I have some small doors I'm selling. Not sure if they're what you're looking for. They're probably more like 1/4 doors. Not sure if this link will work to view the picture of them
here you go... not the best pic but you should be able to get some ideas. I used 3/4" square tubing. Cut off factory door brackets and welded a piece of flat bar 1" by 1/4" the full length (thinking 12" long) i made some hinges with brass inserts. Then i made a frame all the way around leaving a 1/4" gap. I put some cross pcs in to stiffen it up. Where i cut the door in half i welded a piece of square stock 1/2" in side the top tube and they just slide into each other. The only thing i have changed is i painted them black with rhino bedliner to cut down on some noise. With the half door and a summit heater i have had no need to use the tops as the heater will throw you out.
Good luck, there are lots of good ideas on here
1 - 12 of 12 Posts
