hey all, ive got a 09 700 rhino, its all stock accept for a big gun slip on exhaust and wheels and tires that are stock size. yesterday out riding when in High and Low are around 3-10mph while you are just puttin along i get a grinding noise and you can feel something dragging the rhino back. only last for about 3 secs then it will stop for a few min and do it again, its only when your puttin around if your on the gas its normal.... any ideas on where to start looking? i pressure washed the hole thing and there is no visable damage...
emergency brake sticking, cable need some lube?
X2, Next time you drive and it starts to make the noise, pull the emergency brake handle lightly and see if it goes away. Mine would do it when I would drag the bottom over a dune.
