1 - 2 of 2 Posts
Been looking on different webs. about clutch weights.I have installed EPI#WE391053 without changing the springs.Also Clutch Balls.26" Carlisle Mud Wolf tires.
is there a special set of dry weights that I could use that give me a little more UMPF?
Is a 2006 Rhino 450.
Holiday Winner!
Lighter weights will let the engine rev a little higher, so put you into the power band sooner (more power, at least on the low end). I expect the kit you have already has lighter weights, changing weights may not make that much of a difference. Just switching to a dry weight should not change the performance, unless you also change the weight. A machined sheave might help a bit too, if you want to invest.
1 - 2 of 2 Posts
