1 - 9 of 9 Posts
if the water temp comes with a 1/8 NPT pick up u can run it in stock "idiot light" location. some say I can't but mine has been on for a while with no leaks and reads great.
Oil pressure u will have to get a billet in line adapter or tap the big banjo bolt under the stock airbox. and make sure the range is no higher than 60 otherwise it won't read correctly
Why if the gauge goes over 60lbs it won't read right?
well at WOT oil psi is about 40-45 (havent got mine in yet, info from other users). so if its 150 psi guage ur only operating at a small fraction of the gauge. You want to be about half. more accurat readings but im sure a higher gauge will still read close, but not quite as accurate.
Im sure someone smarter than me will explain in better detail lol.
1 - 9 of 9 Posts
