Mine has these full sweep 2-1/16 electrics:
Gaffrig Marine coolant temp guage...love it...
Gaffrig Marine oil psi...actually using a 0-60 fuel psi gauge for best resolution...
Nordskogg digital voltmeter...non-marine...doing it over I would get the cheapest digital voltmeter summit racing sells...coulda go the exact same thing for 50% less...
Autometer Wideband AFR Gauge...works great...not needed with stock motor/carb if you know how to tune properly but indespensible for advanced tuning...
Also have the Trail Tech Vapor computer for programmable speedo, tach, coolant temp, ambient air temp, head temp...the head temp was educational but in the end unnecessary and I would not do the head temp again...way more trouble than it's worth...the trail tech can also be used for oil temp...but it too is more trouble than it's worth by far imo...
Mines 07 so it has fuel gauge...imo fuel gauge is rock bottom in importance if you know your vehicle...you can put a glow light next to the tank and see your fuel level through the crack...or in my case I always had great success in my 05 with no fuel gauge but had digi-dash and used trip meter as fuel gauge...the bottom line is it is super easy to lift the seat...better check your oil level while there regardless of what the psi guage says...
I purchased the fittings from summit racimg and got a 1/8 to AN fitting. I bought the appropriate steel braided AN line. I bought another AN to pipe and plugged the electric sender in.
So that's it...
I was pissed when I got the sender for mine and found out it wouldn'g mount next to the head vertically like yours and even if it would the cvt exhaust would interfere... :indifferent:
Now I know how to adapt it... :biggrin:
