Morning All,
I have purchased a Rhino from an older man that no longer needed it. It was sitting for months not being used, and the guy drained the gas tank to try and keep it clean. I can get the Rhino to run for a couple seconds (it sounds great) but only while applying starter fluid to the top of the intake.It seems that I am getting fuel, as I can rev it up for a short time before it finally dies, but that maybe simply running on the starter fluid. I ordered a new fuel pump, but in the mean time I noticed a line not plugged in coming from the tank. I have added some pictures, and would like some help. 1) What year does this look like to you, how can I find the year? 2) The line I am holding in the picture, where should it go? 3) One of the pictures is where the other gray fuel line plugs into, and it is a 3 line junction, does that look stock? I know the Rhino has been chipped with an exhaust, 300 hours. I live in GA, so no high altitude issues. As of now it seems the fuel line runs from that junction of 3, down to the tank, and than the other line from the tank goes no where. Thanks for any help you can lend!
