1 - 8 of 8 Posts
can anyone tell me if there is a fuse for the 12v plug in. i haven't really looked real closely at the wiring or the plug in itself to see why it aint working. just wondering what fuse if there is one to check?
third one over wicked thanks alot im sure its somthing not as easy to fix. but atleast now i can have a quick look in the morning before i go hunting.
If you need one your your trip, an auto parts store should have one of those ones that clamps onto you battery terminals.
Fuse box is in the battery box labeled Cig I believe. I would almost bet that it is unplugged from the back of the lighter though. Look under the dash and see. Pull back the rubber boot and make sure the wires are still plugged in to the back. The Rhino's are notorious for the connectors coming off. I believe it is a pink wire and a black wire.
1 - 8 of 8 Posts
