I have a 2008 Yamaha rhino 700. The fault code 12 showed up on the display. I found that that is the crankshaft postion sensor. I have change it along with the stator at the same time. But the code still shows up. It there something else I should check? I there a way to clear the code?
Thanks
Thanks
You need to clear the fault code....see video
