:aargh4: Once my rhino gets warmed up the (stock)exhaust starts to squeak. It's loud and annoying, anyone else have this problem or any ideas how to fix it?
Thanks JT
Discussion Starter #2
Bump.....no one has this problem?
well in my experience the squeak is generated by metal movement against metal. Since it does not do it while cold it is a little harder to chase out. The pipe will swell when it gets hot so it could be in the mounts or the pipe connection, even a spring rubbing on a vibrating pipe. you can take a long conduit and put it to your ear and put other end in the general area and maybe isolate the squeak location. Seen them Squeak cause the donut in the pipe joint was worn out.
