Try this.
1 The vehicle has overturned. Raise the vehicle upright. Turning the
main switch to​
ON(however,
the engine cannot
be restarted
unless the main
switch is first
turned
OFF).
2 Installed condition of the lean
angle sensor.
Check for looseness or pinching.
3 Connections
Lean angle sensor coupler
Main wire harness-ECU coupler
Check the coupler for any pins
that may be pulled out.
Check the locking condition of
the coupler.
If there is a malfunction, repair it
and connect the coupler
securely.
4 Defective lean angle sensor.
Execute the diagnostic mode.
(Code No.d08)
Replace if defective.
Refer to
IGNITION SYSTEMin
chapter 9.
