· Banned
Ok I have to pull my motor broke a clutch basket bolt and have to pull the motor how do I get the drive shafts out and do I sake the motor out with the mounts or leave them in ???? And just take the motor ? Do I need to replace any seals when I pull the shafts ???
Thanks in advance guys ( first time pulling the motor ) any other trick let me know
You have to drop the rear diff (or at least unbolt so you can pull it back and down a little), then just pull the rear driveshaft out (be carefull, there is a spring you can loose), Then remove all the motor mount bolts, shift the motor back a little to be able to remove the front driveshaft, and then pull the motor.
Leave the motor mounts on the frame.
No seals need to be replaced.
you gotta pull the rear diff out to get the shaft out there spring loaded so you pull the back one first and the front will slide out when your pulling the motor out,as for the mounts i just undid the bolts from the bottom and left the mount on the motor.get a manuel it brakes all the crap down you need to do good luck
· Premium Member
x
u can leave the rear diff in place and alone,pull out the front diff bolts,slide it forward 2 inches and the shaft pops off the motor, you can pull the motor out with the mounts on the engine too, but when installing undo the front mounts,its makes it easier to align...make sure the spring and boots on the rear shaft go back where they cam from........thats the way I do my motor swaps....
