I have a 2009 Rhino 700fi that is using a little oil.I did check the compression 72 psi I think that is ok with the decompression valve working. I am going to put in New valve seals and was wondering if I should install new piston rings while I am in there. I probably will lap the valves also. Not sure if I am doing the right thing by thinking this way. Would appreciate so advise on the issue. Thank you all
