1 - 2 of 2 Posts
06 rhino hunter
justbought this 2006 rhino and upon arrive home i seen oil on my trailer.here there is a small oil leak on right side of engine .someone had resealed the rankcase cover 1 . can o just remove all the bolts and put the new gasket on.new to this engine and all the parts.what is everything bolted to the case
65015
I have a 2006 450 and if this is the gasket on the passenger side I suggest removing the gas tank for ease of removal and installation. You will need a new gasket and change of oil. Might as well put on a new oil filter. Not hard to do but time consuming. While at it I replaced rubber banding that covered the gas straps, they were cracked and thought better replace them rather than a gas tank. Good luck.
1 - 2 of 2 Posts
