1 - 11 of 11 Posts
2004 Yamaha Rhino 660
Just took the head off my 04 660 Rhino stuck an exhaust valve. Is it OK to build just the top end and not the bottom or would it not be very wise to do that...
Discussion Starter · #3 · (Edited)
I am not sure it was given to me by a friend who got a brand new one....it has been abused. The rear end had been ripped off the brackets that hold the rear chunk had to rebuild those, was running hot when pulling any kind of food plot implement...other than that it cranks and runs....well it did
2006 660 Rhino
Honestly, I am in the same boat. My 06 660 dropped an exhaust valve at 1324 miles and 176 hours. My piston and cylinder are fine, my head may need replacing. Since I am pulling the engine anyway, I will split the cases and do a entire rebuild kit. There are some on ebay (not Chinese crap) for about $900. Might as well look at the bottom end to avoid having an issue later.
Thanks for the tip...keep me posted I will keep you posted, thanks.
Dang, I wish one of you two lived closer to me. I would love to "help" you do the rebuild. Mine is running fine right now, but I would like to be more familiar with the process because I'm sure eventually mine will need to be rebuilt. I would like to do it before it "needs" it so that I can possibly eliminate major damage from it grenading.
2006 660 Rhino
Just to see what's out there, if you decide to rebuild and go BIG, I've read this is a great kit, although more than I will spend. Plus I want to keep using standard pump gas.
Dang, that's more than I paid for my 2004 660 a year and half ago, running and in good shape.
it says you can run on pump or race gas. whatever kit you decide to buy, I haven't had to replace any engine parts yet, but I've read and heard really bad thinks about Niche parts. It doesn't what all of manufacturer for cylinder and head.
2006 660 Rhino
I just put that link in for shock value. I don't plan on replacing anything that isn't worn.
Discussion Starter · #11 ·
Did a little more digging into the engine....fried a rod bearing as well so it's gonna be am entire engine build now....going up a little on the bore and new clutches so it should last a while now!
1 - 11 of 11 Posts
