1 - 2 of 2 Posts
Vendor
LINK: DYNATEK DFS7-26 YAMAHA RHINO 700 IGNITION BOX
I have a few of these in the show case, thought I would pass some savings on to you wonderful forum members.
MSRP $249.95
NOW $199.95
Features
* Removes Speed Limiter * Improved Timing Curves * Higher Rev Limit (8000) * Removes Reverse Speed Limiter * Increased Spark Energy * Improved Throttle Response * Easier Starting * Plug-In Module Replacement (Easy Mounting)
The Dynatek DFS7-26 is for the 08 Rhino 700 EFI.
This plug and play easily installed ECU removes your stock speed limiters in forward and reverse allowing for higher top speed.
Increases your rev limiter from 6600rpm's to 8000rpm's. Advances your timing 4 degrees. has an input for a 15mph limit for inexperienced riders.
The new Dynatek DRSP-1 can be ordered in addition to the DFS7-26 for greater performance and more adjustability and includes Curvemaker programming software that allows for rpm limits to be raised up to 10,000rpm's, and unleash more potential hidden within the Dyna DFS7-26.
4 programmable ignition curves adjustable on the fly. Plus 20%, minus 17.5% fuel adjustability.
1 - 2 of 2 Posts
