1 - 1 of 1 Posts
Designed as an auxiliary light the Double Stryk vehicle kit will illuminate anything you toss at it. Whether you’re on two wheels or four the Double Stryk will keep you on the trail.
The Double Stryk exceeds HID output yet weighs only 138grams.
Uses active Thermal Management, Single Layer Solid Core Copper Circuit Board and aircraft grade aluminum housing that maintains LED temperature within the defined operating limits.
Features:
* Weight: 138g/ 4.8oz
* Waterproof, Submersible to 3 meters
* Hard coated polycarbonate lens
* Combines in house designed spot and driving optics
* Lifetime Warranty
Specifications:
* Total Lumens: 1800 Lumens
* Housing: Billet Machined housing with stainless steel fasteners and mounts.
* Front Lens: Hard coated Polycarbonate
* Power Consumption: 20 watts
* Uses two T6 Bin Cree XML LEDs at 5000K
* 25,000 hour LED life expectancy
1 - 1 of 1 Posts
