Welding the head can be tricky, casting might crack if it cools rapidly in any thin spots-if you try JB weld or putty, the switch needs to find a ground or light will stay on. Could relocate it ,close up the hole with filler or weld -I used a bronze pipe nipple, tap, install sender ,Soldered a ground wire to the nipple, cut the water exit rubber hose about 4 inches down, 2 hose clamps done deal -Was thinking of JB welding a new thermo switch in
How to I ground the switch? If the switch still has some original threads in the casing is it grounded?Welding the head can be tricky, casting might crack if it cools rapidly in any thin spots-if you try JB weld or putty, the switch needs to find a ground or light will stay on. Could relocate it ,close up the hole with filler or weld -I used a bronze pipe nipple, tap, install sender ,Soldered a ground wire to the nipple, cut the water exit rubber hose about 4 inches down, 2 hose clamps done deal -
On the head casting if a filler is used like JB weld it all depends-the filler could isolate the sender completely-cant really just keep tightening into the filler like aluminum….temp light on key on no ground.How to I ground the switch? If the switch still has some original threads in the casing is it grounded?
For what its worth, I had a similar situation on an exhaust manifold stud that had broken the side of the head off. I salvaged what I could from the casting and used Hi Temp JB weld and let it harden for a few days. I did not have a lot of confidence that this would work especially with the heat and vibration. It Has been three years and is still holding like a champ. I am still very surprised !!!Broken thermostat where thermo switch goes. Does this call for a new head? View attachment 65546
Put in a new thermo switch with the jb weld around it. No more red temp light. But doesn't it normally flash when the key is on accessory?On the head casting if a filler is used like JB weld it all depends-the filler could isolate the sender completely-cant really just keep tightening into the filler like aluminum….temp light on key on no ground.
