As far as I know, its all stock except for the electric fuel pump I added.
Does anybody know what the water pressure, and oil temp should be on 2004 660?
oil pressure should be around 10psi at idle and around 30ps at full throttle from what I have read on here.
I have added a new fan with a shroud. I am about to do a couple of good flushes with distilled water and distilled vinegar like Engine Ice recommends and then go back with Engine Ice.
water temp: I found a thread where everyone was posting outside temps and engine temps. At 100 degrees outside, it was 200-210 for most people
www.rhinoforums.net
I am going to be adding gauges for oil pressure, oil temp, water temp and water pressure. I want to be able to glance and see what my temps are and that the oil pump and water pump are working.
I am looking at using glowshift gauges and senders.
Water temp average?????
I'm trying to get a log of water temp average from people with temp guages. I was looking for outside air temp and what your water temp is running. :fingersx: This is what I am running on my 06 660 rhino. outside air temp = 97deg f. water temp = 205-210 deg f. Please help me get a idea on...
