2005 Yamaha Rhino Hunter Ed.
I have an 05 660 with digital dash. I bought it used with very little history. I have noticed that some models of rhino's digital dash have a readout for the fuel gauge on right side of the digital dash. My question is do they all have that or certain years? If certain years could I put one in that has that function in my year rhino?
That is the plan, I just didn't know if our year was capable or if they started later. I found the sending unit I want to use. I just would like to have it in the digital dash insted of mounting one in or under the dash.
I figured for sure that someone would have figured this out already and done the ground work. I will have to do some research of part numbers to see if they are the same or different. I don't know anybody with the newer years to see if they plug in the same. I hate to go buying a newer digital dash just to play around with it.
It looks like digital dash part numbers are the same through 06 and then 2008 and on
5UG-W0081-00-00 2006 660
5UG-83500-22-00 2007 660
5B4-83500-01-00 2008 700fi
5B4-83500-01-00 2009 700 fi
I would like to know if the gauges from a 2008 and later will work on our 05-06 models. I wonder if they changed the gauges to integrate the fuel sending unit only or if they changed the plugs ect for the 700 fi models. They still show three plugs.
