1 - 2 of 2 Posts
I have a 2007 660 rhino, 84Hrs 600 Mi, and engine rev limiter kicks in when you try to engage differential lock. Diff lock never engages and engine rpm is limited to 1000 rpm . Note 4wd will not kick in either. (In neither Low or High range) 3amp fuse to 4wd motor is OK and there is 12 volts to said fuse . Symptoms are, 4wd indicator light blinks and there is no emblem of 4 tire vehicle on LCD screen. (UTV Operates correctily in 2wd.)
Any suggestions as to where i would go next to find/fix Diff lock issue?
1 - 2 of 2 Posts
