1 - 2 of 2 Posts
Will my Inner CV Housing be ok with some small damage from cage fail and axle tore up the housing a bit. Want to see if I replace with new rebuild kit that it will hold up ok.
Scott, here's the thing... You could "get away" with using your existing inner cup, but the damage is not good. And... The splines are wore down.. If you're tight for money, take a thin file to the splines to clear the "path". The "cup" needs to be de-burred something fierce as well...
Honestly though? Rebuild kit. Not worth putting the effort into the pieces you've taken pictures of. It'll work, but reliability? No...
1 - 2 of 2 Posts
