Here a are couple pics of my 06 Rhino. I just installed a custom aluminum roof and a custom stereo system which I mounted 4 6.5" speakers in a steel panel and welded to the top of my roll cage. What do you guys think?
That should work for you....if you want to pick up some of the bumper plugs I picked some up off of Ebay for around $7 delivered.
looks good, how did you attach your aluminum roof to your roll cage and thickness did you use?
Discussion Starter #4
Thanks guys. I plan on building both front and rear bumpers in the near future so I'm not concerned about end caps.
I used 1/8" aluminum and I drilled and tapped my roll cage and used stainless bolts to mount it to the cage.
Looks great, i have that same cd player collecting dust in my garage and thanks to you i just found a use for it.
