1 - 20 of 25 Posts
Ok, I just put a 686 kit on my rhino. Took it out for 2 hours and it ran great! Stopped at a friends house for a second and when I left it started to overheat. Now its filling up the coolant overflow reservior and spitting all the coolant out the overflow's overlow tube. What is going on? Head gasket?
No coolant in the oil. My temp gauge went about 230-240 and it started blowing coolant on my feet. Now when fill it with coolant and drive it down the street the overflow fills up and starts lowing coolant out on my feet when its not even hot.
I have heard of this problem before but I can't remember what the cause was...
Do you use the stock radiator cap...not that is should matter if not overheating...
And where did you install your temp sender for your gauge...
Is the fan turning on/off like it should...
You should do two things...
Make sure the system is bled as was said above by Josh...
The other is find out if it's the relay or the thermal switch causing your fan not to come on...
If you had air in the system originally that could be the whole problem...the sender will register hot when it's really not and the temp of the coolant in the radiator will not be hot enough to turn on fan and air in system could be the reason it spits out...air expands when hot...
Very possible that is your only problem...
I just bled the system as stated above and drove down the street. Immediately at full throttle the coolant overflow filled up and started blowing coolant out the overflow tube.
The most likely thing it is the head gasket.....................
I saw this lots on my Raptor, when overdoing it a bit during oval races.................
You DID use a new head gasket when you installed your 686 kit, right? :)
If it happens so quick (without time to get to normal temperature) and starts blowing out the coolant right away - it's probably the head gasket. Sucks!!!!
Building enough pressure to lift the cap before it gets hot sounds like a head gasket. I would do a leak-down test if possible. What did you torque the head to and what kind of head gasket did you use?
Nate
Alba Racing
Its either an air pocket or a bad headgasket. My money is on the hg's though. If you rev motor does it change the amount or force of the water coming out? You can buy a kit that indicates if combustion gases are in the coolant.
Where are all the air bleeds mounted on a rhino?
Yes it was a new head gasket and I do have a head stud kit. I torqued it to factory specs. Would a bad radiator cap be the problem too?
Doubtful. I would think that if the coolant coming out of the radiator isnt hot then there would be no other way of getting pressure than though the combustion chamber.
Oh yeah, I used a cometic head gasket
What part number? Was it a 102mm kit? I think it should be C7798.
Nate
Alba Racing
1 - 20 of 25 Posts
