$450 obo plus shipping.
This is a used comet 108 4-pro clutch with adaptor plate and adaptor spline to remove the stock internal wet clutch on the rhino.
I have an assortment of weights as well as an additional springs to go along with it for tuning to your motor needs. I will also include an additional clutch cover for modding since it will need to be hacked up and extended out to seal the clutch setup. the clutch worked fine the only thing that needs replacing is the center reverse thread screw which can be purchased for $29.90 off eBay. Comet Mounting Bolt for 108 Exp 4 Pro Clutch 217158A | eBay
I will upload the images tomorrow once it is cleaned and ready to ship. i don't expect shipping to be much but can get you an estimated quote if there is interest in the clutch setup.
for more info PM or text me at five two zero 312-9190
Are you planing on hitting up mud or water? If so you would have to make a custom cover with the extra cover im supplying. I didnt need it since i live in az and its hot AF
Sent from my iPhone
