starting to get colder up here north in washington....and i came up with a tip ...and thought i would pass along....on my rhino....the choke will not stay out?...not sure if only mine does that?....but i found at work a rubber washer about the size of a quarter but about 1/4 thick...it has a hole in the center....so i cut from the center to the out side edge like a pizza slice out of the rubber...and a tiny hole by the edge with real fine wire and connected the wire to my key....so this rubber washer hangs by my key from this thin wire and when you go to start get the rubber washer and pull choke out and stick washer between knobe and dash...the thickness of washer keeps rhino running and the wire keeps it close by...
Now you tell me!...Sheeez...Thanks Shawn,,,named my first son shawn...Thanks man
