Quit running while in backing up...,was on flat ground. Checked the code...lean angle sensor....checked voltage from sensor got 4.9 volts.....check battery show good voltage put bad under load replaced.....still same code...checked relay power to relay but none to fuel pump....2 days later went to check turn key on battery was dead...
Aint seen that one yet
Had problems not starting before......before sending a while back to shop...pressure washed it started......dielectric grease every thing in fuse box ran a while until now.....could this be a possible ground issue......
Could b, have u ever done the frame grounding mod on it?
Do a google search, basically the batt is grounded to the motor so you add a ground wire from there to ur frame 10ga. I believe then u can ground all ur accessories to the frame rather than grounding them to the battery. Even if u dont have accessories it helps
