1 - 1 of 1 Posts
Hello. I have a 2006,660 and it has an aftermarket clutch. It was acting like it was “shifting” around 40mph. So it took the sheave apart and haven’t seen one like this. It says “stage 3” on it. The weights are two piece where the middle threads out. I think they are plastic on the outside and the threaded part is also plastic. There is some small flat spots on the weights. Everything looks in pretty good condition. Do you guys see any reason to not clean it up, grease it and run it again? It used to do 58mph. Thanks
65072
65073
65074
65075
65076
1 - 1 of 1 Posts
