1 - 2 of 2 Posts
Looking for experience with niche clutch housing part #5KM-16611-10-00. I know niche is a bad word when it comes to top end kits but was wondering if anyone has any experience with clutch parts and possibly even primary. My clutch needs attention and started to slug wet clutch but I can’t get the collar between fixed and primary sheave off of the shaft so think I may have to cut it off just to check out wet clutch. Btw machine is a 06 rhino 660. Thanks for any input
Engineer
Mix oil and acetone together and drip it into the collar hole. You may have to wait over night. Apply heat and tap gently with a hammer to unfreeze it. Do not try to cut off, it is hardened. I always coat my cvt shafts lightly with TinkSeal before replacing the collar.
1 - 2 of 2 Posts
