When I start my rhino with it in neautral the primary clutch is automatically engaging as if I have my foot on the gas. Then if you try to put it in gear it lunges forward and dies. I took the primary off and checked all of the weights and slides they are intact and in the correct place. When you give it gas while in neautral the clutches and belts are moving correctly but when you let off of the gas the primary never disengages the belt is it still spinning as if my foot is still on the gas. It is a 2009 Rhino 700 with a EPI secondary spring, primary weights and springs.
