Hey hi all, I'm replacing my second clutch belt on my 2006 450. Why? Anyone else had a similar problem? Am I pushing it too hard on open road? Thanks.
You definately are not pushing it too hard on open road, I have held my 700 wide open for 15 miles down the road with two 300lb men in the front and a load in the back. Are you using yamaha belts?? You definately wan't to use oem yamaha belts, don't use anything aftermarket. If you are using yamaha belts then something is going on. unless you have like 10,000 miles on it you should not be changing your belt for the second time. These belts should last forever, do you have access to a clutch alignment tool? a dealer can place one on your clutches and see if the alignmnt is off although I have not heard of this happening with a rhino it does happen with sleds....
Broke drive belts
I have a 2012 700 with only 550 miles on
It and gone through 4 belts, if u even try
to ride a rhino hard its ganna break, all i do
is creek and mud ride broke belts, 6 axles and
blown head gasket, they are junk, be like me
give rhino to kids to ride n yard and get a
polais "any kind" or Canam and be done!!
