1 - 1 of 1 Posts
Hi,
I have a Rhino that's been sitting for a year. I've not driven it very far because the left front wheel is locking up every so often. You need to put it in 4WD to make it spin again. It's not the brakes. When I spin the wheel, it tries to turn the front drive shaft until there is enough pressure to clunk the wheel around about 30 degrees and then it does it again. The right hand wheel spins smoothly. Not that I'm an expert, but it doesn't feel like a CV problem to me. There's no movement in the hub wheel bearing.
When it was parked up, I didn't notice any problem like this. I was busy with brake issues.
I'm reluctant to pull the whole thing apart if it's something that happens when they are immobile for a while and might go away with some use. Any help would be greatly appreciated.
Thanks
Russell
1 - 1 of 1 Posts
