hay guys got rhino running but I think carb is get to much air got air box on and when running my hand over the hole it run fine but when I remove it run like **** then dyes so how do I a just the air fuel mixer thanks :fingersx:
There is a screw on the bottom side of the carb. If it has never been adjusted there may still be a brass plug covering it. Just drill it out and the screw is under it. Should be around 2 ta 2 1/2 turns out from all the way in.
Well you dont have to take it out completely but it is easier that way.
You can try loosening the clamps on the intake and airbox boots and rotate the carb 180 degrees. The screw is on the bottom.
For a second I thought this was an OT thread where it was being discussed dieting :ROFLMAO:.... ever since I've been monitoring my sugar I've been in a weird space lately :(
