I recently bought a 2006 Rhino 660. After changing the fuel pump and priming the fuel system it fired right up and runs like a top but... if you start it up in Neutral and shift into High Gear it’ll jump forward and die. Same going from neutral to reverse. It has to be started in the desired gear which of course causes it to jump while it’s starting and then just take off once it’s started. A friend of mine said it’s the One Way Bearing but I can’t find any info about the OWB causing this particular issue. Any help to get me pointed in the right direction would be greatly appreciated. Thank you all in advance!
