1 - 2 of 2 Posts
Do you have to pull the head in order to change the cam shaft? It looks like you can pull the timing sprocket cover off and remove it from there.
Thats the way the 700 works-Hunterworks has a vid on the swap as well as one on youtube of a raptor cam change(just ignore the valve removal unless your gonna change the valve springs also.I used a hotcam in my 700 that increases the duration that the valves are open-so no valve spring replacement is required(acording to hotcam)Ive got close to 1000 miles on mine since the cam upgrade & It has been rock solid & a real seat of the pants upgrade!Keep in mind this is all for the 700-so do your research-Good luck & dont forget you need some sort of fuel controller to increase fuel-I used the MSD with hunterworks maps in mine.
1 - 2 of 2 Posts
