For those of you that have built your own cages, what material did you use? I'm designing a 2-seater race style cage and am going to use chromoly just not sure on wall thickness. 090 or 120?
Just make sure to use the black stuff, not the white stuff OK?I am starting a new cage design, this one is going to be a 2 seater unlike you have ever seen... the coolest thing about it is that i am going to save tons in weight. I plan on using pvc tubing from home depot, I will keep you guys posted, I might start selling these puppies!
hell i just maybe able to enhance your idea. anyone want a newspaper cage??? after you roll it just throw it into your recycling bin. plus as you're riding you can read the news
i was trying not to go for the BING BING look![]()
No, dont use newspaper, use aluminum foil!
I suppose that a layer of powder coat would blow the weight budget? :23:i was trying not to go for the BING BING look
Yea fortunatly I have a bend-tech program that helps take some of the guessing out of where to bend. I'll still pick up a stick or so extra because its bound to happen. If not i'll have it for making custom bumpers. Its been about 3-4 years since I built a couple jeep cages..095 1 3/4 inch DOM on all main parts, and 1 1/2 DOM on x bars and 1" for and grab bars. I have used about 65 feet so far just on the main structure.
You have to remember that you will make some mistakes here and there. I messed up on the length of one B piller and mis-notched a couple smaller tubes. I bought 80 feet of 1 3/4 initally.
I would recommend buying some regular welded tubing to practice with.
And write everything down that you do. Length of tube before your bend, degrees of bend, ect.
no, just you one less cross bar and the wieght budget will be right on:fingersx:I suppose that a layer of powder coat would blow the weight budget? :23:
or a few copies...or let me know where i could pick one up at.You wouldn't want to make me a copy of the Bend Tech program would ya????
