Hey guys I was working on my rhino doing various things to it non engine related. Probably over a month. Once I was done I took it out to ride and it was smoking abit. I checked oil and it had a small gray streak in it. I thought that was odd so I flushed the oil a couple times and put new oil and filter in it. Now it smokes worse and burns it faster than fuel. Spark plug has oil on it and if you put your finger in the exhaust pipe it comes out covered in raw oil. Compression test showed 110psi on it. I haven’t tore the engine apart as I’m buying a Viking but want to start working on it aswell. Any ideas would be helpful. It’s a 2009 rhino 700
