1 - 18 of 18 Posts
I have a question i am about to put new mud lite 28-12-12 on my rhino which is not lifted or anything it is stock with the old tires being 25-10-12. I am 95% sure i have more than enough clearence just thought i would as if anyone had done that and if i will be fine like i think i will thanks??
I have 30 inch zillas on my 07 660. I have a two inch lift but dont really think my lift gave me a true 2 inches. I think you will be fine.
also is it ok to put the same size width wise in the front as the back??
I thought about using all the same size when I need need tires...I'm gonna get a spare front tire/wheel to mount on the machine...I have 27" 14s ITP XTRs on my 07 660...not a problem with stock suspension...
There are much better tires out there than the crappy ML, I had them and the only thing they were good for was collecting holes.
Zilla's, Mudbugs, GBC dirt devil II's
I have 27" Zilla's on one machine and 27" Mud bugs on another. IMO I wouldn't go larger than a 27" tall tire.
And as for the same width all around, nope,.. I wouldn't go wider than a 10" on the front,.. or too hard to turn.
Discussion Starter #7
I did not even think about it being harder to turn i hope they dont rub though i already bought them 150 for all four new just could not say no
The Mudlites run short and puncture easy... I accumualted about 45 plugs in less than 1,300 miles. They are also very hard to turn and the sidewalls are paper thin... They are pretty good in the mud but I went with 27" Bighorns and never looked back... The Mudbug is also a better tire than the Mudlites in my experience.. The MLs are worth the $150 you paid IMO however.
tires
I just put 28x12x12 on the rear and 28x10x12 on mine and had a 2 in lift on it. I did not like the Super ATV 2 in lift so I took it off. Tires do just fine. I have the 2 in factory spacers on the rear and 1 1/2 on the front.
there is no tire better than a big horn any tire that can hold up to the arizona razor sharp rocks always has my vote
are you guys talking about the mud lite xtr's that you are plugging? i would think the radial mud lite would be much tougher. big horns would be my choice if i lived in the desert, but i have my doubts on how well they do in the mud.
Yeah, I was looking at buying a new rhino and the dealer wanted to put Big Horns on it. Where I hunt/ride it's muddy. No rocks but there are Ironwood trees (I think that's what they're called....huge thorns like nails). A buddy of mine has ML's on his ATV. Never had a flat and gets good performance in the mud out of the tires. We have gumbo mud so you need something that will clean out easily. I bought a used Rhino with the ITP Terra Cross tires on it. They do ok as long as in 4wd, but slick over pretty quickly. Probably a good all around tire though. I think ML's would work better than the Big Horns or Terra Cross where I ride.
If you like the Mud lite tires but don't want the hassle of them look at the Supergrip Super Light DL 1.25".
SUPER GRIP ATV Tires and Wheels
***Aggressive Tread Pattern For The Most EXTREME TERRAIN!
***Full 6 Ply Casing To Resist Punctures For The Most EXTREME RIDERS & CONDITIONS!
***1.25" Deep Lug Available in 25", 26", 27" & 28"
***Super Grip Signature "Rim Guard" & "Enhanced Rubber Compound" For MAXIMUM TIRE LIFE & TREAD WEAR!
***Lighter Than It's Competition With Longer Tread Life Under ALL CONDITIONS
I'm interested in duplicating your wheels/tires and lift kit. Can you give me leads on where you purchased the stuff to do these mods?
1 - 18 of 18 Posts
