1 - 17 of 17 Posts
hey im thinking about swapping out my stock tires on my 660 rhino for some good all around tires, now i just got some real agressive tires for my foreman that are great but a little to much for my rhino cause i dont do any mudding with it but could use more traction! now i dont want a heavy tire cause rhinos dont have that much power so i still wanna be able to spin them easy! and i want a nice strong sidewall to help with some stability! thanks for anything you say!
Strong sidewalls and lightweight are a contradiction in terms...
My personal favorite is the Carlisle, 4-pr, AT-489 25x11x12 on all four corners with 1.5" or 2.0" spacers on the rear only...
That is the best non-paddle sand tire and is one of the best in snow...not so great in mud...they are very light weight, have directional tread for excellent steering/handling...even with fat ones in front...and it helps to have same wheel tire on all four corners for a variety of reasons...
NOT a tough tire...compares to ITP 6-pr tires...which are NOT tough tires either...same g/c as stock tires...
If you keep the air pressure up they will not cut as easy and be easier to spin on hard-pack...and the wide footprint helps with stability along with the correct offset wheels and spacers in the rear...
They are one of ... if not the cheapest tires you can find anywhere for the Rhino that are worth having...
DON'T GET the cheaper and more available versions of that tire in 2-pr and 3-pr... for one they don't come in 11" wide in those ratings...and the max pressure is too low...they are not strong enough IMO....
Not saying the 489s are "best" for what you want but IMO the shortest/lightest tire that will to the job is what is best...
Not sure from what you said if DO or DO NOT need traction...??? But the 489s do hook up well on hard pack IMO...
I'm loving the Big Horn originals that I just put on a week ago. Everyone here swore by them and now I know why!
NOT everyone... lol...
And if we get together in the sand or snow sometime YOU will find out why...
And I KNOW what you are thinking and NO you are NOT going to bait me into getting into sharp rocks... I don't do rocks...!
:biggrin:
Bighorns ARE very good tires and very tough with super smooth ride ... not lightweight at all and poor steering/traction by comparison to tires that DO ...
:biggrin:
I think my bighorns work great in the snow! I ride in all sorts of stuff and love them. 18xx miles and not one problem. Still over half tread left.
Original Bighorns are a great all-around tire.
Speaking only from atv experience.
Bighorns are a good trail tire. Do everything well but fall very short in any kind of mud.
Mudbugs are good at everything including mud. Trail manners aren't quite as good as bighorns but the mud capabilities out weight that. Very smooth ride for a more aggressive.tire as well. Anything more aggressive rides very rough!!!
And to think my stock tires were great in sand..... NOT
These are a huge upgrade and the chances of me mud bogging, riding in snow or using them at the dunes is pretty nil.
:biggrin:
big horn originals all the way!!!! great radial tire that will last and last and last!!!! if you dont like wasting money buying tires all the time,then this tire is for u,unless ure a dunner then u better get u some paddles!!! but for trail and pavement,this tire lasts!!!
489's are a good all around tire that last.
You should get a six ply tire and keep them aired up.
We play out in the mud and ride trails,waiting to wear my factory ones out. Have bearclaws on the back of my polaris 500,they bite good, clean out well, but are fairly stiff
:biggrin:
x2:banana::banana::banana:
i heard big horns are a good solid light tire.
I have been researching tires as well. I have heard multiple opinions.
Several things to consider...probably don't want to go over 26". if you are running in hard pack or rocky terrain or even on roads, you may want to consider radials for the ride and wear.
The opinion that I have put the most stock in is regarding STI Black Diamond XTR. either 25 or 26". they are radial, DOT approved and hold up to a ton of wear/use. I use my rhino on asphalt about 50% of the time and from what I hear they can go 3000 miles with barely any wear. They run a bit heavy but I'm not racing. Will probably buy 25-8-12 for fronts and 25-10-12 for backs with 1.5 inch spacer in rear.
1 - 17 of 17 Posts
