i know there is lots of discussion on front diffs and 4wd drive issues but i cant find anything that helps me out. I have a 2009 rhino 700 SE and last time out in the snow i may have engaged the diff lock and got on the throttle a little prematurely, the initial problem was the 4wd light on my dash wouldn't go out So ive taken the 4wd drive motor off and it looks like the shift fork inside the diff is bent and not engaging the diff lock. How can i remove the shift fork to either replace or straighten it? Thanks. steve
