installed my sheave with .75mm shim..how high should belt ride on secondary? looks like it may be rubbing
Vendor
It will ride to the top of the secondary and stick out a little bit. If it is rubbing the belt might have a little stretch to it (from being used). If it is brand new and is rubbing the case, I would double check the cam plate and weight installation to double check its on all the way and isn't letting the primary open a little more than it should. If it all looks good and still is rubbing, rev it for a few seconds and see if it just clears the case up a little bit. On some of the old 660 sheaves we used to see the belt rub a small groove into the cover but it wouldn't ever be an issue or cause harm to the clutch.
Sent from my T-Mobile G2 using Tapatalk
the grooves plus a little more stick up over sheave..ill let it run for a while and recheck it..if its barely rubbing ill let old belt ware it down then add new belt
